opnspaces
Apr 13, 2014Navigator III
Personally I would go for the $40 savings. Just ask the person you're buying the trailer from to go make it level front to back and measure the coupler height. I would imagine with how much you are paying for the trailer that they will be willing to do this for you.
One thing I don't like about the balls they sell at Walmart is they are rated kind of low for my tastes. Their 2 5/16 ball is rated for 6,000 lbs, while at the RV dealer I picked up a 2 5/16 ball rated at 10,000 lbs for a dollar more.
Another option is to go to Walmart and buy one of each drop hitch and the big wrench that they have hanging next to the display. Then go to the dealer and buy the ball and have them put it on the correct drop hitch. Stop at Walmart on the way home to buy some camping supplies for the new trailer and return the unused hitches while you're there.
If for some reason the dealer won't install the ball for you (for free) then just use the wrench that you picked up to install the ball. Once you get it tight, turn the hitch sideways in the receiver tube so you can push down on the wrench to tighten the nut. Now just grab the tailgate for balance and step up onto the wrench using your weight to tighten it further. If you're particularly light give it a bounce while you're standing on the wrench and it will be tight enough.
