rbpru wrote:
But, the fact remains that I try to adjust the WD links so the TT is level with the TV or maybe a bit lower in the front; then weigh the combo to see what the max cargo and axel loads are.
rbpru wrote:If you're talking about the front and rear fenders of your EcoBoost F-150, I believe you've misinterpreted Ford's specification for adjusting a weight distribution hitch.
My best results have been to do what the TT dealer and Ford suggests. I put the TT on the ball, adjust the links so the TT sits level and the change in the height of the fenders at the wheels is about the same front and rear.
The online 2011 F-150 Owners Guide specifies:
Weight-distributing hitch
When hooking-up a trailer using a weight-distributing hitch, always use the following procedure:
1. Park the vehicle (without the trailer) on a level surface.
2. Measure the height of the top of the front wheel opening on the fender, this is H1.
3. Attach the trailer to the vehicle without the weight distributing bars connected.
4. Measure the height of the top of the front wheel opening on the fender a second time, this is H2.
5. Install and adjust the tension in the weight distributing bars so that the height of the front fender is approximately halfway between H1 and H2.
6. Check that the trailer is level. If not level, adjust the ball height accordingly and repeat Steps 3–6.
Beginning in MY 2015, Ford changed Step 5 to read:
5. Install and adjust the tension in the weight-distributing bars so that the height of your vehicle's front wheel opening on the fender is approximately a quarter the way down from H2, toward H1.
(underline and bold added for emphasis}
Neither of Ford's specifications state that the change in the height of the fenders at the wheels should be about the same front and rear.
Both specifications require the front end to be above the unhitched height, and that means the rear end will be below the unhitched height.
If you're adjusting your WDH to cause nearly equal front and rear "squat", you're transferring significantly more load to the front axle than Ford calls for.
I don't know if Ford ever specified "equal squat", but I do know that since 2007 Ford has specified that the front end should be at or above the unhitched height.
Ron
