Ron_Gratz
Jan 12, 2016Explorer
hohenwald48 wrote:You don't need to weigh the TT unhitched.
I think I might be getting a little confused here. I don't see why you need to disconnect the trailer from the TV to get TW. Just relax the spring bars, subtract the weight of the TV unhitched from the weight of the TV hitched (with spring bars relaxed) and you get the true TW. Why to you need to weigh the TT unhitched if you already have the weight of the TV unhitched?
If the scale operator will allow you to release the load from the WD bars while on the scales, you could make two separate weighings in one pass - one with WD activated and one with WD not activated.
If not, you would need to make three passes to get the full set of weights.
Ron
44,070 PostsLatest Activity: Aug 05, 2026
