Old-Biscuit
Nov 02, 2020Explorer III
WELCOME!!!
Water heater.....has separate controls. Gas On/Off switch inside (could have electric also inside or in outside compartment)
Brand/Model??
Furnace.....controlled by Thermostat on wall
Select HEAT
Turn temp set point UP to desired temperature
Fan comes on...slight delay/runs to purge combustion chamber then should hear 'Click, Click, Click' from ignitor/electrode then Flame comes on
Heats to temp set point...flame goes out...fan runs for cool down cycle then repeats when room temp drops 2-3* below thermostat set point
Brand/Model of Furnace and Thermostat would be helpful for us to help you
Also should post Year/Brand/Model of RV
Brand/Model??
Select HEAT
