rmaukExplorerNov 02, 2020How do I run propane furnace but not hot water heaterNewbie here. Due to freezing temps, I want to run the furnace on low but with all water drained, but not winterized yet. How do I run the furnace but not the hot water tank?
ppineExplorer IIINov 02, 2020Drain the water heater and switch over the bypass valve so you don't fill it with anti-freeze.
Related ContentFurnace using too much propaneMore efficient propane furnacePropane furnace issuePropane/ FurnacePropane Furnace vs. Electric Space Heater
