CharlesinGA
Nov 06, 2020Explorer
rmauk wrote:
Watched the videos on anode rods. Thank you.
The issue here is that there are two brands of water heaters, Surburban, which has a steel tank and the anode rod, and the electric switch on the outside on the LH side hidden by some wiring and other stuff.
The other brand is Atwood, now Dometic, and they have an aluminum tank and NO anode rod. They have a plastic drain plug on the LH lower corner of the tank.
In either case, drain the tank.
Charles
