spud1957
Sep 11, 2019Explorer
4x4ord wrote:
I think the manufacturers tow ratings make better sense now than they ever did. The thing people need to be aware of is that HD3/4 tons are identical to 1 tons other than they have less leafs in the rear springs which prevent them from being able to carry much of a trailer. Once the manufactures stop producing these useless 3/4 tons and put the 3/4 ton badging on the 1 ton SRW everything will make sense..... it will be if a half ton won't do it you gets a 3/4 (which will be sprung like a present day 1ton SRW) if the 3/4 ton doesn't cut it you get a 1 ton which means you get duals
The comparison changed in '17+ for Ford. The 350 does have a couple add'l spring leafs but the big difference they changed starting in '17 is the the 350 has a Dana M275 axle. Different from the 250's Sterling.
You are able to get the Dana M275 axle in the 250 if you order the diesel WITH the High Capacity Trailer Tow option.
