troubledwaters
Sep 13, 2019Nomad
IdaD wrote:Yes I will concede that what you are saying about cushion etc. is probably a valid point. My statement was too overly broad.troubledwaters wrote:IdaD wrote:Maybe it wasn't clear, "Comparable duty point" was intended to mean an F150 operating at 100% of its tow rating (or whatever parameter you want to compare) compared to a F350 operating at 100% of its tow rating ( or whatever rating you're comparing). 100% vs. 100%troubledwaters wrote:
There is no evidence to indicate an F150 can't tow all day every day within its tow ratings without incurring any more adverse effects than a F350 would at the comparable duty point.
This is the comment that everybody is calling BS on. Throw a 10k lb trailer behind an F150 and the same behind and F350 and there's no question which truck will wear better over time.
Okay I did read that wrong and that does make your point more defensible. I still don't agree with it in a lot of cases, though. My 2500 has mostly the same components as a same year DRW 3500...which would make me think there's quite a bit of cushion built into the ratings on my truck. I also think heavy duty trucks are built to a higher standard in terms of expected duty cycle. Same deal when you go to a MDT...and so on as you move up the food chain.
