Buzzcut1
Apr 04, 2021Nomad II
Malone wrote:
From https://autowise.com/diesel-engine-failure-bosch-cp4-lawsuits-roll-on/
“Unfortunately, there’s no such retrofit kit for the Ford 6.7 Power Strokes because of the way the CP4 pump is mounted in the engine. However, S&S does offer a CP4.2 bypass kit (aka “Disaster Prevention Kit‘) which reroutes fuel from the pump’s bottom end back to the tank and filters.
S&S Diesel Motorsport’s “Disaster Prevention Kit” doesn’t keep the Bosch CP4 in Ford Power Stroke 6.7Ls from failing. But it does prevent the pump debris from circulating through the entire fuel system.”
This re-routing prevents metal debris from contaminating the rest of the high-pressure system if/when a failure occurs.
yep the bypass will save the engine but a dead fuel pump will still leave you stranded. I bought my truck used, no telling what fuel or additives were used. I was getting ready to haul my horses from San Francisco Bay area to Lexington KY when I found out about the fuel pump issue. no way I was going to get stuck out in the middle of nowhere with the horses. New Pump and I add extra Lubricity additives to the fuel tank with each fill up.
