Old-Biscuit
Feb 17, 2017Explorer III
I am one that has been labeled 'weight police' and that's OK by me.......I don't care
Here are MY Standards
OK if over Trucks GVWR........many times that is a number that can be massaged IE: can be register at higher GVWR
I use RAWR, Rear Tire Max Load Ratings and CGVWR
If at/under the above then hookup and tow
Over on any then a 'personal decision' has to be made.....use axle mfg. specs, change rear tires/wheels to higher load rating.
2005 2500 is good up to 12K 5th wheel----14K is too much weight
I tow 14K with my 2007 3500.......maxed out on RAWR/Rear Tire Max Load ratings and over on Trucks GVWR (10,100---scaled at 10,800 with 2980 pin weight)
Again ..to much trailer for your 2005 2500.
