helpmetow
Feb 19, 2017Explorer
Cummins12V98 wrote:
"That said I didn't level my TV so maybe I would need 70 psi to level 1.5" of squat."
IMHO your truck is already "level" when hitched. 70psi would most likely extend springs higher than stock form hitched. The people you see heading down the highway towing at stock ride height are running those high numbers most likely thinking they need to get the truck to look like it does solo when towing.
Then ya get "why does my truck ride so rough" ?
Again I just quickly threw some air in the bags from a large compressor, 70psi happened real fast and I just went about my way. The truck doesn't need all that air by any means, nor will it see that much under normal use
