Ron_Gratz
Apr 14, 2014Explorer
Shorteelaw wrote:If you mean that the receiver's max TW is 940# when using a WDH,
Our WDH max tongue weight is 940.
then it appears that, assuming a TW% of 13% --
the maximum allowable loaded trailer weight would be 940/0.13 = 7230#.
It appears the receivers rating is limiting how much trailer you can get.
In your case of 900# available payload, if you do not exceed the receiver's TW rating,
you should be under the GCWR, TV's GVWR, and TV's rear GAWR.
Ron
44,068 PostsLatest Activity: Apr 17, 2021
