ah64id wrote:
Based on my experience with TT's you won't have an issue with tongue weight on the return trip. Check the fill TW, make sure it's not too much and enjoy.
IMHO if you have a close scale then a TW scale is a waste of money, figure out where you are at and retest when you make major loading changes.
To determine TW from scale weights, you must:
1) weigh the TV with the TT unhooked, and
2) weigh the TV with the TT attached and with the WD not activated.
It is much easier to measure the TW at home with a Sherline scale.
And, if the TW is going to vary as much as some are speculating,
the TW should be measured before leaving and
before returning.
Just a reminder, if you have 900 of payload remaining you only have about 800 after a WDH. Really you should be looking for a trailer with a TW of 750 max, or max GVW of 5000-5500, the empty weight of 4000 still is looking pretty solid.---
IF the 900# of payload stated in the first post
did not account for the weight of a WDH, then the trailer-induced vertical load should be limited to about 800# (assuming 100# for the WDH).
If they are using a WDH to restore the TV's front axle to its unhitched load --
the resulting vertical load applied to the TV will be about 80% of the TT's tongue weight.
If the TV's available payload is 800#, the maximum allowable tongue weight, based on TV's GVWR, will be approximately 800/0.8 = 1000#.
However, as we now know, the receiver's TW limit is 940#.
With a typical TW% of 13%, the corresponding maximum allowable TT weight would be about 940/0.13 = 7230#.
And assuming they can keep the loaded weight to 1000# above the dry weight, the dry weight could be about 6200#.
If you prefer to use an atypical TW% of 15%, the corresponding TT weight would be about 6270%.
Corresponding dry weight would be about 5200#.
Ron
