_1nobby
Oct 28, 2016Explorer
al7601 wrote:
*Remove the small screen over the inlet and push in on the valve with a small screwdriver until you see antifreeze. Replace the screen
There may or may not be water in that "City Water" line.
Chances are....if he used the onboard water pump to flush all his lines with antifreeze that that 2 feet of line probably got bled off.......but...he'll never know until spring, eh?
Best bet is to fire up the water pump again and press in that check valve until red comes out.
In this pic....the screen is already removed.
44,060 PostsLatest Activity: Mar 28, 2026
