SoundGuy
Oct 28, 2016Explorer
#1nobby wrote:
Best bet is to fire up the water pump again and press in that check valve until red comes out.
"Best bet" is to IGNORE this erroneous advice and NOT push in that check valve stem with the system under full pressure, as YOU found out yourself. Instead, turn the pump OFF, open a faucet for a few seconds to relieve some of the pressure in the system, then push in that check valve stem. Do it this way and you won't displace the rubber O ring inside the check valve, causing it to leak.
44,060 PostsLatest Activity: Mar 28, 2026
