Photomike
May 04, 2020Explorer III
I towed a support trailer. Most of the time it wasn't an issue. Only time I ran into a problem was if I ended up going down a dead end road or trail.
My Dad always told me to park so if you needed to get out you could. Seems simple but so true. Park at the back of a lot, park in the RV spots, park so your truck is aimed to pull out. Use your brains as others probably won't when they park around you.
When visiting places if it is close to your campground leave the trailer. If you cannot leave the trailer park in RV spots.
Security, I always locked the tongue so nobody could hook up to it.
Best advice I can give you is to learn to drive properly and know your units. You will need to do some fancy driving at times so learn before hand what you can do. My worst predicament was puling into a camping spot. Only a couple spots were remaining at the campground. The guy who checked me in said it was EASY to get into. SURE IT WAS!!!!!!!!!!!!!! Maybe if you were driving a bicycle a mini or a Smart car. After several tries my boys and I disconnected the trailer and pushed it back in to the spot and it stayed there for the entire stay.
