wnjj wrote:
6pac wrote:
TC has to be level if using gas ref . If using AC voltage not so much...
The fridge doesn't care what the heat source is. It needs to be close to level on gas or AC. The reason is the coolant circulates by gravity through a spiral tube set. It can't flow uphill.
Correct. You should have a lower vent panel outside the camper behind where the fridge is. If you open that you should see the tubes the coolant circulates in. If you look at the picture of the back of my old fridge you can see them (2nd picture):
My fridge replacement projectYou can see how that flattened coil of pipe makes 5 loops around and the coolant has to be able to flow down those. As you can see from the picture it wouldn't take much angle at all to cause liquid to pool at the downhill side of the coils. Since the fridge is mounted facing across the camper and the coils are therefore arranged fore-aft I suspect that it would be more tolerant of side-to-side slopes when parked than fore-aft slopes.
Steve.
