crazybill
Nov 08, 2014Explorer
I have a 96 Bronco 1200 and I can tell you that even on propane that fridge is marginal at best. The problem is with the side ventilation on the rear of the fridge. Just doesn't work the best. I replaced the cooling unit on mine and added three muffin fans on the back and it works just OK now on hot days.
Since you already said you want to go electric I would echo the others who suggested a compressor type fridge and solar setup.
Operating the current fridge on 12 volt when not driving is not feasible. In addition to the 12 amp draw of the heating element, the wiring is too small. This adds to the load when on 12 volt. Not unsafe, just an added load.
If I had it to do over again I would go the compressor fridge route.
If you're going the electric route with your other appliances then you are going to need solar anyway. I have 120 watts on mine.
Hope this helps.
-Bill-
Hope this helps.
-Bill-
44,056 PostsLatest Activity: Jan 12, 2020
