Boatycall
Sep 24, 2017Explorer
I'm going to chime in and say length alone will have little bearing on handling.
I, like many others here, have had several TCs over the years. I had an 11.5' Real-Lite on an F250. I've had a 9.5' on that same truck, then moved on to single-slides, and now my dual slide.
I can say without a doubt that height and weight are far bigger factors than length. Length on it's own won't be a factor since most all are designed with a mostly normal COG. Add slides, now it's heavier. Make the inside floor go over bed the rails like mine, vs inside the box like my previous Arctic Fox's, and now you have a taller TC, which tends to sway more.
All but one of my TC's were 11.5'. Weight and height made me go from an F250, to a 350, and now a 450. Length alone was not the factor.
