kohldad
Sep 24, 2017Explorer III
Since you are going custom build, the 84" CA would be my choice. Longer wheel base does ride better and will allow you to have the COG in front of the axle for sure.
However, look at the front axle capacity and see if how much it has to spare. Then do some calculations on how far forward you think the COG will be and make sure the front axle can handle the weight. You may find the shorter CA would work better.
