imq707s's avatar
imq707s
How long should caulking hold up before redoing it?
I've had our 2011 Crossroads Zinger for close to three year now. When I first got it I went through everything and cleaned out the old caulking on all of the joints, and redid it. Then last summer I noticed that some of that caulking had started to crack and look pretty bad so I redid a bunch of it again.
And now this summer/fall I've started to notice that once again, I can see several spots were the caulking around things has started to pull away and/or crack...and needs to be redone.
I've always used the high quality (and expensive) RV caulk, and it just doesn't seem to last very long.
Is that pretty normal, or am I doing it wrong??
  • Sure. You should inspect the roof, and really all seams three or four times a year. Wash the roof a couple times a year. Recaulk as necessary. Its part of what is necessary to keep an RV in good shape.
    What did you use last time on the seams?
