PSUJIM85
Oct 05, 2014Explorer
palmwhit wrote:
Our Lance 1181 has 2 7 gallon tanks and they hold more than 20#! Propane weighs a shade over 4# per gallon which is why a 7 gallon tank is referred to as a 30# tank 7X4.125= 28.87#. I realize that's not the question, but the capacity and useful duration are going to be quite different between a 5 or 7 gallon. But make sure you know which size tank you actually have. The biggest draw is going to be from a propane generator, which is why we avoid using ours if we are going to be needing a lot of AC, then we take along the Yamaha(gasoline but more efficient).
You have a propane generator but use a gasoline one? How does it hook up to work. Do you take the propane one out to run it? Do you run off batteries for AC?
