MORSNOW
Oct 05, 2014Navigator III
PSUJIM85 wrote:
You have a propane generator but use a gasoline one? How does it hook up to work. Do you take the propane one out to run it? Do you run off batteries for AC?
The propane generator is mounted in/on the camper and runs off the propane tanks that also fuel your refer, furnace, water heater, etc. The gasoline generator is a portable unit that you connect to the camper with the 30a shore power cable. Both will provide 120v power to the camper.
