ryoung
Jun 08, 2014Explorer
If you need an engineer to explain tire pressures, just read the door placard on your vehicle. The placard on my dually says to inflate tires to 65 psi at maximum rated load which if I recall is a little over 9000 lbs. I would assume that an engineer came up with this number. So why should I disbelieve him and run 80 psi?
ryoung
ryoung
44,068 PostsLatest Activity: Jun 01, 2026
