APT
Mar 16, 2016Explorer
Your receiver limit is 1000 pounds. That's about 7000-7500 pounds loaded TT, or closer to 6k dry. Next limit is payload. Say you have 1400 pounds available based on options and equipment and the family weighs about 600 pounds total. That leaves 800 pounds left for loaded trailer tongue weight, or closer to 6000 pounds loaded.
I recommend checking this sticker on your driver's door for as equipped payload. Note what yours has where mine says 2051.
Also, check the sticker in the glove box for 3-character RPO codes. You want to confirm that it has GU6, K5L, and KNP for the 8000 pound tow rating, or you may only be at 6000-ish pounds.
