spoon059
Jul 13, 2014Explorer III
BenK wrote:
Like the front disc's between my era's 3/4 ton and 1 ton look the exact same...but
the disc is thicker, the caliper holds a thicker pad, the MC has bigger bores,
the rear wheel cylinder has bigger bores, the proportioning valve is different
as are the rest of the suspension.
Can anyone tell the difference between a 8.6K GVWR torsion bar vs a 9.6K GVWR torsion bar?
Without reading the part number and/or weighing it?
My buddy has the 6.0 F250, so early to mid 2000's MY. Brakes, axles, wheels, frame, etc is all the same between 250 and 350 that year. The only difference is the suspension. He mentioned overload spring, I assume it also has the block as well. Everything else is the same between the 2 vehicles.
44,066 PostsLatest Activity: Jul 25, 2018
