rhagfo
Mar 01, 2014Explorer III
I believe the OP is referring to a TC Truck Camper AKA Drop In. Well the #1 issue is the 6" lift, that just makes the TC more top heavy.
Air bags will like help if on separate fill lines. The addition of a rear sway bar will help also.
What size and load range are the tires on you 3500, big floater tires will not help either.
The best option would be to drop the lift, but I would doubt that would be an option.
44,052 PostsLatest Activity: Oct 09, 2025
