Cummins12V98
Mar 02, 2014Explorer III
TheHardWay9 wrote:
New to this forum, and looking for some help. I purchased a 10.0 Camp Lite TC for my 07 3500 Cummins. The truck is lifted 6" so I am dealing with some sag and sway going down the road, and this is before I add the wakeboard boat to the equation.
I've done some research online and have come to the conclusion that one option is the Firestone air bags that mount outside of the frame. I like the Pac Brake bags, but they mount inside the frame, and the mounting brackets would interfere with the brackets for my traction bars.
The other option is the StableLoad from Tork Lift. They claim these things are a good starting point, over bags... that they reduce sway, and level the truck by engaging the overload springs sooner. However I'm wondering how much they help, and if they will be enough for my application.
So....I understand bags will greatly help with the leveling aspect, but how much do they help with sway? Do they make it worse? I'm already at a disadvantage with sway due to the increased COG from the lift, and I don't want to make it worse. I'm looking to level the truck and add as much stability as possible.
Haven't really looked into rear sway bars, and I think the traction bars would interfere. But for the heck of it, what are some of the popular rear sway bar options out there?
Any input would be appreciated. Anyone running a setup similar to me? Recommend one option over the other?
I think your handle says it best "the hard way" put your truck down to the stock configuration or you may learn the hard way that towing can have serious consequences!
44,052 PostsLatest Activity: Oct 09, 2025
