rytech1
Mar 02, 2014Explorer
Air bags are good for leveling the load but if you get above your overloads you will make your sway worse. I ended up putting the helwig overload replacements and a swaybar which helped alot. You are probably not going to be able to use the sway bar with a lifted truck though.
Towing should handle better than with the camper alone, I notice the truck handles well while towing my X10.
44,052 PostsLatest Activity: Oct 09, 2025
