okan-star
Mar 04, 2014Explorer
TheHardWay9 how is the rear of your truck lifted , if its just with blocks , then the geometry of the leafs and overloads above is as it was stock right? then you could put stable loads on it if you have factory overloads . Or supersprings will work with or without factory overloads , I personally would go with the supersprings
If you have addaleafs that are lifting the rear then the distance from the factory overloads to the bump stops is increased and neither stableloads or supersprings are going to work , unless you can add a taller block between the top of the main spring pack and the factory overloads and or the supersprings
44,052 PostsLatest Activity: Oct 14, 2025
