okan-star
Mar 05, 2014Explorer
billtex wrote:homefor2 wrote:
With anything but minimum air (10-15 lbs) they lift the truck off the overloads
Sounds like you had no need for airbags (other than leveling), or the stableloads...
Measure 2x...cut once.
Setting up a truck to properly handle a TC is a learning experience!
Exactly , I think any thing but dealing with the stiffness and capacity of your springs is just a band aid and a waste of money
I had my 2500 dodge first and put airbags on it in 2004 , had 3 popups on it and it was ok , never put much air in
Bought a 3500 Dodge dually as a second truck for a larger camper and knew I didnt want bags on it , went with supersprings
Now I have a Lance on the 2500 and the bags came off , I didnt want to spend $ on stable loads just to try so I drilled 1 more hole for each bumpstop and lowered them , its ok , way better that the sway with bags , even with 5 lbs in them, but Im getting supersprings or new progressive leafs from http://www.generalspringkc.com/Leaf_Springs_s/1817.htm
As soon as I can afford them , leaning tward superspring so the ride un loaded is still ok
Any one thats interested in airlift bags for a ford up to 04 or a dodge up to 02 , pm me an I`ll make you a almost gift of the bags I took off
44,051 PostsLatest Activity: Oct 02, 2025
