silversand
Mar 05, 2014Explorer
....I think that your question Isn't answerable without testing equipment set up on your specific rig, with a specific air bag (air spring) ?
In my mind, if you use air springs, then you have a more complicated situation, because you now effectively have 2 air springs (ie. your rear/front tires are essentially air springs, and add this tire behavior to the air spring behaviour associated with each rear wheel = 2 air springs per rear wheel).
I did a bit of reading on air springs ("finite element analysis of an air spring for automobile suspension"). There are several ways to look at the air spring: using FEA, and experiential. If experiential approach s used, then it is almost impossible to "measure" empirically "how much sway"; using FEA, you could run various scenarios (on the isolated bags, then isolated tire response, then both, under a set of conditions, etc)...
Any engineers out there who may elaborate more than my limited understanding?
44,051 PostsLatest Activity: Oct 02, 2025
