- PadlinExplorerI carry a 5 gallon, use around 1/3 to 1/2 so somewhere around 2 gallons.
- LEMIIExplorer
Stefonius wrote:
We have a 45 gallon black tank. After dumping, I take a 3 gallon cat litter bucket, put in 1 cup of Calgon powdered water softener and 1 cup of el cheapo generic powdered laundry soap, fill the bucket with about 2.5 gallons of water, stir to dissolve the powders, then dump it down the toilet (the Geo method). I then refill the bucket with water and dump it down the toilet again. This gives me enough liquid (hopefully) to account for evaporation between trips, and as an added bonus it gets the toilet bowl so clean that I can't look directly at it without sunglasses!
I'm going to try this method for the first time this weekend...I hope to have as much success as you.
Thanks. - summertime_blueExplorer
Old-Biscuit wrote:
path1 wrote:
After dumping, I fill up the toilet and flush 3 times. Don't know the amount of water in gallons or pints but I know I've never had any problems with black water tank. Sometimes if I think about it I'll toss some laundry soap or dish soap if going to travel far before I dump again.
X2...except I only do 2 toilet bowls
50 gallon black tank.
all of this plus a bag of ice before I hit the road, that's enough to get the tank spic and span! - galexanderExplorerI use a 2 gallon bucket, add treatment to bucket,add water to bucket,stir to mix treatment,dump into Black Tank and refill bucket with water and dump into tank again.
- Dog_FolksExplorer II
1kennyOG wrote:
Just in general I know tanks are not all the same size but I have a 21' HTT the black tank is 22 gallons.
I want to keep some liquid in there sloshing around when I travelling (after dump) how much do you figure would cover the bottom?
If the tank is 22 gallons then 2 gallons will do it.
I would use at least a three gallon bucket to prevent spillage. :) - StefoniusExplorerWe have a 45 gallon black tank. After dumping, I take a 3 gallon cat litter bucket, put in 1 cup of Calgon powdered water softener and 1 cup of el cheapo generic powdered laundry soap, fill the bucket with about 2.5 gallons of water, stir to dissolve the powders, then dump it down the toilet (the Geo method). I then refill the bucket with water and dump it down the toilet again. This gives me enough liquid (hopefully) to account for evaporation between trips, and as an added bonus it gets the toilet bowl so clean that I can't look directly at it without sunglasses!
- fla-gypsyExplorerYou would need to know the tank dimensions to accurately answer this question
- 1kennyOGExplorermy toilet holds less than 2 gallons.
I also dump in 2 gallons of an enzyme digester. it digests the******where soap just makes bubbles and perfume :) - RVnRobinExplorerFirst one full toilet bowl of water.
Second one full toilet bowl of water with one pint of PineSol. It must be 7-8 gallons.
When outside temps are above 90 degrees I use one quart of PineSol because the high temps seem to "cook" our waste and produces some odor before the tank gets full.
Last nights low temp was 102 degrees. I'm using one quart PineSol each time right now. - bikendanExplorerwe always do 2-3 gallons.
