Cummins12V98 wrote:
4x4ord wrote:
I've had as much as 11000 lbs on the pin on my SRW F350. The other day I used it to tow a piece of equipment that weighed over 36000 lbs and it seemed safe enough to me so long as I stayed under 50 mph.... it didnt have brakes. I go by you can do what you want as long as it seems safe to you.
Curious how did the rear tires look with 7k pushing down on each of them?
I actually don't recall if I even looked at the tires that particular time, but here is a picture showing a rear tire when I had 8k on the pin:
