- 352Explorer II
fj12ryder wrote:
352 wrote:
Okay, now there's a guy with a sense of humor. :)
Every time I change my engine oil. Every 2,000 miles to be safe and you should too.
My kind of guy. You fingered it out - IdaDExplorerThe first change is the most important because it seems like there's more debris in it, and that goes for diffs, transfer cases and transmissions. Subsequent intervals could probably be extended. I suppose that's because the initial wear creates more metal shavings than later when everything is smoothed off.
- Adam_RExplorerI'm guilty of changing stuff too soon, or at least sooner than the OEM "recommended" intervals. I've been changing diff, tranny and xfer case fluids at 30,000 miles. Each of my vehicles have in the neighborhood of 250,000 miles on them. Not a single mechanical failure (lubricant related) among them and everything operates as close to a 'new' vehicle as you can get. I've upped oil changes from 4000 to 5000 miles recently and I rotate the tires at the same time I change the oil. Yes it's sooner than you could get away with, but I doubt the OEM's want our vehicles to last forever. If it lasts forever, you'd be less inclined to buy a new one.
- blt2skiModeratorHere I thought it were check fuel level while filling engine with oil?!?!?
Marty - GrooverExplorer II
DownTheAvenue wrote:
ParkCountry wrote:
What is your regimen?
I have found that reading, understanding, and following the owner's manual always works best!
That is good advice unless you know that you did something well outside of normal operating range. One tidbit that I have found in two of my manuals that does not seem to be widely followed is to put the transmission in neutral if you are going to be stopped for several minutes to reduce heat buildup. - DownTheAvenueExplorer
I have found that reading, understanding, and following the owner's manual always works best! - Grit_dogTrailblazer
wnjj wrote:
Fluid may be "cheap insurance" but you're slightly increasing the risk of failure. What if you make a mistake when changing it? E.g. Wrong level of fluid, contamination or create a leak. Some things are better left alone for longer periods.
While I don't think changing diff juice as a matter of course every 3-4 oil changes is even remotely necessary, the slight risk of failure is really non existent. Like saying brushing your teeth twice a day doubles your risk of getting toothpaste in your eye! - DurbExplorer
What? I'll change mine when I replace my transmission filter and adjust the bands at 30,000 mile intervals. I already have a cast aluminum differential cover with drain plug and full synthetic. Fear of doing simple maintenance just isn't in my wheel house. - wnjjExplorer IIFluid may be "cheap insurance" but you're slightly increasing the risk of failure. What if you make a mistake when changing it? E.g. Wrong level of fluid, contamination or create a leak. Some things are better left alone for longer periods.
- dodge_guyExplorer III do my trans and rear diff every 25k miles. Fluid is cheap compared to a repair due to lack of maintenance.
44,068 PostsLatest Activity: Apr 17, 2021
