- Adam_RExplorerI'm guilty of changing stuff too soon, or at least sooner than the OEM "recommended" intervals. I've been changing diff, tranny and xfer case fluids at 30,000 miles. Each of my vehicles have in the neighborhood of 250,000 miles on them. Not a single mechanical failure (lubricant related) among them and everything operates as close to a 'new' vehicle as you can get. I've upped oil changes from 4000 to 5000 miles recently and I rotate the tires at the same time I change the oil. Yes it's sooner than you could get away with, but I doubt the OEM's want our vehicles to last forever. If it lasts forever, you'd be less inclined to buy a new one.
- IdaDExplorerThe first change is the most important because it seems like there's more debris in it, and that goes for diffs, transfer cases and transmissions. Subsequent intervals could probably be extended. I suppose that's because the initial wear creates more metal shavings than later when everything is smoothed off.
- 352Explorer
fj12ryder wrote:
352 wrote:
Okay, now there's a guy with a sense of humor. :)
Every time I change my engine oil. Every 2,000 miles to be safe and you should too.
My kind of guy. You fingered it out
44,029 PostsLatest Activity: Jan 20, 2025
