Tennessee_NomadExplorerApr 02, 2014How often to repack wheel bearings on TTHow often do you all repack the wheel bearings on your TT's. Should it be done every year or a specified mileage/usage. Thanks for your advice!
K_CharlesExplorerApr 02, 2014If you use the trailer often then 20 or 30,000 miles would be good but if you let it set for months at a time then every year.
Related ContentWheel bearing repackingWheel Bearing RepackBearing repack - hub noises?Repacking the wheel bearingsWheel Bearing Repacking question
