TheGreatWaz00 wrote:
OK the Mrs and I have chosen a TT, Rockwood 8311SS. It is within my tow limit, the question I have is the payload number. How critical is it to be below your payload number?
I have a Ram 1500, with a payload rating of 1266. I have 800# of passenger and gasoline. The Hitch weight is 746 for the TT so I would have a payload of 1546 - basically 300# over the rated 1266 number.
You are way off on your numbers. That 746 is unloaded hitch weight. The unloaded weight of the trailer is 7180 with GVWR of 8400 lbs.
Once you and the dealer get done loading propane, battery, dishes, pots and pans, flatware, bedding, BBQ, camp chairs, groceries, and water. That trailer will easily reach 8000 lbs with tongue weight around 1000. With WD hitch, you will need 11 - 1200 lbs of payload, just to support the trailer.
In one of your previous posts, you stated your truck has 1266 payload and 7700 lbs max towing capacity. Once you put 800 lbs of people and cargo in your truck, your max towing capacity is no longer 7700 lbs. It drops pound for pound of what you put in the truck. Max tow capacity is now 6900 lbs. Your max tow capacity will be exceeded by about 300 lbs, before you and the dealer do your loading.
You will be over not just on payload and tow capacity. GVWR and GCVWR will also be over weight.
You will have a very unpleasant towing experience.
