Drew_K
Jun 27, 2014Explorer
About the oven, I wouldn't obsess about having one. Just get a large toaster oven, which should cover just about anything you bake except for a turkey. Plus, you can run it off electricity rather than use up your propane, and, in hot weather, you can bake outside rather than heating up the inside of the RV. RV's typically have enough trouble trying to cool as it is - no need to run a big heat box inside as well.
If you plan on boondocking a lot, then maybe you want the built in oven.
44,056 PostsLatest Activity: May 04, 2014
