TundraTowerExplorerJan 04, 2017How to correct uneven "Bump Clearance" ?I have a slight sag on the passenger side of our travel trailer. After extensive measurements, I find the bump clearance is actually less on the right side. Bump clearance is the space between the...Show More
RWjSIM2003ExplorerJan 04, 2017Sounds like you should have 5000lbs axels on the trailer. I think I would have passed with only 787lbs CCC.
Related Content13'5" clearanceHard baseball sized "bump" outside RVAir bags or "Bump Stop" type suspensionHit a Speed Bump then "Crunch"Correct Truck
