TundraTowerExplorerJan 04, 2017How to correct uneven "Bump Clearance" ?I have a slight sag on the passenger side of our travel trailer. After extensive measurements, I find the bump clearance is actually less on the right side. Bump clearance is the space between the...Show More
Boband4ExplorerJan 04, 2017Could you flip the axle mounts to the underside of the springs? It would raise the trailer box and gain you some clearance.
Related Content13'5" clearanceHard baseball sized "bump" outside RVAir bags or "Bump Stop" type suspensionHit a Speed Bump then "Crunch"Correct Truck
