spike99
Jan 05, 2017Explorer
Many trailer makers design their suspension system on "minimum" specs and nothing more. And, this is after 13% tongue weight is subtracted from Trailer's GVWR number. This allows cost savings - which means more profits in their pockets.
If planning to keep Trailer a few more years, I would simply take trailer's GVWR weight number and divide by 2. Then, round up to obtain Axle & leaf spring pack size. For example.... If trailer has 7,855 GVWR, then /2 = 3,927.5 lbs. I would then replace its existing axles with 2 x 4,200 lbs and 4,000 lbs springs. If 4,200 isn't available, then go with +1 size of of 4,500 lbs (axles and springs). Especially if one packs heavy.
Note: Doing +1 size upgrades doesn't mean one can exceed 7,855 GVWR number. +1 allows for extra buffer of rough roads and/or extra support from trailer's heavy side - from a pull in slide.
If wondering, I always +1 size all my trailers (utility, RV, boat) and it works great. Yes, I do the work myself. And where possible, I also upgrade their tires (rubber) as well. Money well spent - especially if keeping trailer for many years.
Note: When ordering new Leaf Spring packs, remember to order Leaf Spring packs with needed arc shape as well. If proper arch shape isn't available, then re-design using Leaf Spring Packs "on top" of axle tubes (instead of default under axle tubes). This works for me.
