path1
May 05, 2013Explorer
Try any ford VIN decoder to see what the spec are on truck. And also look at door sticker of "axle group" Then there should be a axle tag on rear diff. get the numbers off it and look it up.
http://www.google.com/#hl=en&gs_rn=12&gs_ri=psy-ab&cp=7&gs_id=s&xhr=t&q=ford+vin+decoder&es_nrs=true&pf=p&output=search&sclient=psy-ab&oq=ford+vi&gs_l=&pbx=1&bav=on.2,or.r_qf.&bvm=bv.45960087,d.cGE&fp=771fa58581d29b28&biw=1366&bih=622
http://www.google.com/#hl=en&gs_rn=12&gs_ri=psy-ab&pq=ford%20vin%20decoder&cp=13&gs_id=3p&xhr=t&q=ford+axle+tag+codes&es_nrs=true&pf=p&sclient=psy-ab&oq=ford+axle+tag&gs_l=&pbx=1&bav=on.2,or.r_qf.&bvm=bv.45960087,d.cGE&fp=771fa58581d29b28&biw=1366&bih=622
Takes awhile but worth it. I thought I had a 4:10 ratio but using axle tag have 3:73 Also while under there changed diff grease/oil. Never thought I would spend $20.00 a quart for oil but that is what it goes for.
Hope this helps.
Hope this helps.
44,056 PostsLatest Activity: May 04, 2014
