Ivylog
May 05, 2013Explorer III
OP, I have a 02 F250 PSD 4X4 with the manual tranny and 3.73... great truck. Mine has the camper package that adds the rear F350 helper spring and sway bar on the rear. Check and see if you have these two items as then you should look at the F350 ratings. Unfortunately this does not change the door sticker as I sometimes gross over 26K pulling an equipment trailer where I can adjust the pin weight. You could add the extra 350 spring as the axle and brakes are the same as a F350.
44,056 PostsLatest Activity: May 04, 2014
