TCINTN's avatar
TCINTN
How to get scratches out of headlight covers 2006 Dodge
Someone told me that there is a way to remove dullness in the plastic covers which are over my headlights.
Truck is a 2006 Dodge 3500
Thanks
  • Tom in CT wrote:
    Be sure to coat your headlights with a UV protecting wax afterwards or they will fog over again fairly quickly.
    Something like this - http://www.autogeek.net/meguiars-headlight-protectant.html?productid=meguiars-headlight-protectant&channelid=FROOG&utm_source=CSEs&utm_medium=GoogleProductSearch&utm_campaign=CSE&gclid=COLei-Ck8roCFZNlOgodUn8ARw
    Clicky
  • Be sure to coat your headlights with a UV protecting wax afterwards or they will fog over again fairly quickly.
  • Tooth paste and a buffing pad. It is a reel fine grit. Cheap
    (Not the powder)
  • azwildcat99 wrote:
    I found a simple method on YouTube and it works well. Wet sand with 2000grit sandpaper and then use an some NuFinish scratch remover with an orbital buffer. I've done this on three different cars so far and it was easy and worked great.
    An old boaters trick for you.... when you wet sand put a few drops of dish soap in the water. Works great and you will spend a lot less time for far better results. :C
  • I found a simple method on YouTube and it works well. Wet sand with 2000grit sandpaper and then use an some NuFinish scratch remover with an orbital buffer. I've done this on three different cars so far and it was easy and worked great.
  • go to auto parts store Mothers polish makes a Kit that will polish them back to clear. There are other brands also that will do the same thing
