Scheinweifferma
Mar 07, 2020Explorer
mich800 wrote:dodge guy wrote:
The new LED headlights the OEMs are offering are just as bad for blinding people. I’ve seen it myself. So if you don’t like LED headlights, then you may want to speed to the manuf and thy government for allowing brighter lights!
OEM too bright.
Except that recall isn't about the "headlights" being too bright per se. It's the fact that the Daytime Running Lights on the truck can be enabled at night with the regular low beam headlights.
That's not the low beam headlight being "too bright." That's a programming screw up by Ford.
Daytime Running Lights are, as the name implies, for daytime use, and therefore they can be a little too bright for safe nighttime use. Every other car disables use of the DRLs with low beam headlights. Ford didn't.
44,065 PostsLatest Activity: Apr 14, 2026
