dedmiston wrote:
Thanks everyone.
I found THIS on Amazon and it looks like it fits my inflator.
I'll get under there when I get home tonight and figure out where the inside stems are.
"THEY" should be on the opposite side as the outer ones. I do have to admit, my 05 dualy, one was in the middle of the holes. Not likely to get to that one!
But the picture of the amazon filler is the best one IMHO to get. Sometimes the inner is angled like the outer one. Unless you have LARGE holes in the rims, you many times can not get that style to work. You can also find pressure guages with the same head shape, that are 15-18" long or there abouts. Around $30-40, but I have had three of them for over 20 years, still showing the same pressures against other ones as they did back then.
Marty
