I went through the same thing with my 2014 F350. Bought a good double checker and also inhaler. Still had trouble. Harder to get down and check then it use to be. Getting older. Finally after a lot of research no RV Net and and other advice I ordered extensions that have the flexible. This puts everything on the outside tire. It does have to be quality. There are those that have leakage problems and etc. Sorry I don't remember the brand I bought, but they are good. Probably ordered off Amazon. Biggest problem the bolt that holds it to the outside wheel must be tight are it will work loose.The nut is hard to get to but this device is well worth it. They were not exactly cheap.
