Boatycall
Apr 11, 2014Explorer
Old-Biscuit wrote:
Reason there won't be enough room is the area where the add on adjustable t-stat is installed would be where the 110V t-stat set would be if WH was combo gas/electric.
Exactly. My is gas-only. If you have 12v and 110v, there will be a complete second set of the thermostats for the 110v, right were I put my mod.
As with any thermostat, the Home Repo thermostat has to touch the tank itself with no other insulation or metal in the way. What you could do is somewhere on the inside of the TC, cut away some of the Styrofoam insulation off the top of the tank (or whereever you can get to) and put your Tstat mod there.
Just a thought....
