Oasisbob wrote:
Lay cover on ground correctly positioned. Use two poles. One person on each side walk the cover back and over the top. Carefully going over AC . That's how wedid it. Stay off the roof.
Maybe 2 expandable aluminum poles like the pool guy uses with hooks on the end might work. Start at the back with one person at each corner walking it forward on each side, adjusting the length of the pole as needed. My wife could probably stitch a canvas loop at the upper corners of the cover to hook on to. You guys might be on to something....
I'm definitely going to get one of those telescoping 12.5' latters. I've got just the spot to store it in the trailer.
thanks for the input.
